bbonn ‘C:\Users\bbonnor\AppData\Roaming\tonfotos\db’: Realm file initial open failed: Invalid streaming format cookie (1120140829780111685) Path:Exception backtrace:
Ups, that is bad… Looks like the internal database crashed. Any idea what happened? Hardware reset? App crash?
Anyway, the solution is still the same - you will need to uninstall and reinstall application back. This will trigger creating database from the scratch. Unfortunately, it will take time for full recognition of all your photos, but don’t worry all the work with faces will be fully restored - Tonfotos keeps this data not only in the internal database, but also in ini files right next to photos. Same with metadata editing - this information is stored inside photo files.
Please read this to better understand where Tonfotos stores its data: https://tonfotos.com/docs/library/setup/#data-files
Sorry that you had to face this issue and now will need to wait again until all images will be indexed again.
