Hi i got a DQHD display (5120×1440) and when i have the program over the full display, it scales up the image previews as well. The problem is, that they get way to big, i already have the slider for the preview size at the lowest.
i think ideal would be, if the images stay the same size, independend of the windows size or format(x/y). (currently: scale with the window.width)
p.s.: if someone works on this, maybe also make the slider a bit bigger and reach smaller and bigger values, currently it is a small slider with a lot of room for it to be wider and more accurate to adjust then.
nontheless thank you in advance, i would be happy to hear about this, even tho this might be rather a special problem 😅 , p.p.s: love this app 😃
