Marleen9 Well, this forum is about Tonfotos, so I hope you can understand we don’t provide detailed support for other applications here. However I can name some of them that you can use to check if the face metadata is there. My personal go to tool for anything for photo metadata is exiftool
, but this is a console utility so it is not for everyone. Alternatively you can use Faststone image viewer
, it will not only show you the metadata, but can actually display embedded face regions. Both apps are free.
