Thank you very much for your quick answer, I appreciate the service, it’s really great.
I understand the sync should be done through the dossier file, assuming we enable the dossier file on both copies. This is what I have done, but it does not sync smoothly.
I have checked. On PC A (named DOUCET-PC2), the library is images, with dossier file enabled. . On PC B, the library is \DOUCET-PC2\images, with dossier file enabled. I can access the same people.tnfp file from the 2 PCs. I have made some modifications (names and relations) this morning at 11 am, I can see them in the file. But today at 6pm, they are not synced on PC B. Does it take that long?
